Insulating Pipes In Garage Ceiling ? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2013, 11:42 AM   #1
Rewards Points: 85
Insulating pipes in garage ceiling ?
Hello,
I'm currently finishing our two-door garage and I have access to the ceiling above the garage. Above the garage we have a bedroom. That being said, between the garage ceiling and the bedroom there's a space about 32" high. In that space, there are two 6" pipes feeding the floor vents in the bedroom. There are also two additional 6" pipes - a return pipe and another one to feed heat in that space.
Since I have access to this space I was wondering if I should take the opportunity to insulate the HVAC pipes ?
The garage ceiling is insulated with R40 batt insulation.
westbank is offline   Reply With Quote
Old 10-11-2013, 02:27 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
Not going to do anything useful or pay for itself. the heat that radiates from them is keeping that space warm and you need some heat in there probably for the water pipes. R40 is great so that space is warm anyway. would be different if it was running thru an uninsulated space.
The Following User Says Thank You to yuri For This Useful Post:
westbank (10-15-2013)
Old 10-11-2013, 06:08 PM   #3
Rewards Points: 424
With the unit in the cooling mode I would think a good sealed insulation job of the pipes would prevent condensation and a wet ceiling.
Old 10-11-2013, 06:43 PM   #4
Hvac Pro
yuri's Avatar
The heat for that space pipe should have its damper shut in the Summer and re-opened for Winter. Doubt it could ever get that cold in that space for sweating.
Insulating an attached garage CooperRex Insulation 3 03-12-2013 10:39 AM
Garage renovation/vaulted ceiling & removing "ceiling joists" brandonlaundry Building & Construction 7 02-20-2011 12:27 PM
Ugly Ceiling pipes! What to do? vfxhouse General DIY Discussions 11 08-31-2009 02:01 PM
insulating a garage ceiling, a bit different question scooterw Building & Construction 1 09-15-2008 10:45 PM
