Insulating An Octopus - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 08:37 AM   #1
the Musigician
DangerMouse's Avatar
Insulating an Octopus
We now have 2 types of ducts in the crawl space. Sheet metal plenum and box with flex-duct coming out all over. I need to insulate the sheet metal parts and am wondering what the cheapest/best way to do so would be? Foam sheets with the edges 'glued' with GSFoam? Wrapped batts? Any other ways?
Thanks Guys!
DM
Old 12-11-2010, 08:43 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Must be heat resistant/fire rated. Foam can give off toxic fumes if overheated or in a fire and doubt if it is legal to use for that reason. They want closed cell foam in crawl spaces for external walls etc here to meet code. If it does not meet the bldg code you may have a hard time selling the house if it gets inspected later. I would use the foil backed wrap from HDepot and large washers and self tapping screws to hold it on.
Your local sheet metal shop may have those self adhesive hangers and they are the best to use. Has a washer to slide on the pin which has barbs on in.
http://www.durodynecanada.ca/canada/..._fast_menu.htm
Old 12-11-2010, 09:18 AM   #3
the Musigician
I enclosed and insulated the crawl space walls already. But I'm sure there's still some heat loss.
All my work has been inspected and has passed, so no worries there. I'm just baffled as to the best way to insulate the exposed steel.
DM
Old 12-11-2010, 10:37 AM   #4
Foil backed duct wrap and lots of tape. I'd use inch and a half insulation with a pound and a half density if the duct doesn't already have a liner in it.
The Following User Says Thank You to Marty S. For This Useful Post:
DangerMouse (12-11-2010)
Old 12-11-2010, 10:40 AM   #5
the Musigician
I wonder what THAT's going to cost us.... lol
*sigh* It never ends, does it?
DM
Old 12-11-2010, 11:11 AM   #6
Rewards Points: 264
Hi DM,
I see that you have enclosed your crawlspace. Could you PM me about how you did it or post here:
Crawlspace Wall Insulation
Thanks.
Earnie is offline   Reply With Quote
Old 12-11-2010, 11:18 AM   #7
the Musigician
6"x6" framing, " ground contact plywood 2' up outside, same thing 12" inside. I put sheet foam in first and then added 6" batt. Then I used some particle board to finish sealing it up. I went around later and GS Foamed anywhere I felt a draft or saw any light coming through.
DM
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 01:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
