Insulating The Hot Water Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 09:40 AM   #1
insulating the hot water pipe
Hi guys Im doing my basement - I have my baseboard piping coming down and I want to insulate this before I start building out the walls.
http://www.lowes.com/pd_145681-1410-...%7C1&facetInfo=
What do they use for these hot water pipes
thanks!
ItsaDucati2012 is offline   Reply With Quote
Old 01-15-2013, 09:44 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 568
thanks!
Any of those will work- the fiberglass type is used extensively on commercial projects
Old 01-15-2013, 11:55 AM   #3
I insulated the hot water copper pipes in my crawl-space using foam pipe wraps (sold at Home Depot and Lowes Home Centers). These store generally stock pipe-wraps for at least two different copper pipe diameters. These foam wraps are slit along its length so it's easy to slip it over the pipes. Both stores carry a self-seal version that has adhesive on both seams along the slit. For installation in a cramped and dusty environment, the self-sealing wrap is well worth the extra cost, even though the adhesive can dry out after a year, as I found out. I fixed the problem by wrapping a good grade duct-tape over the pipe wrapping to reseal the seam.
dpny is offline   Reply With Quote
Old 01-16-2013, 07:20 AM   #4
frost king
I got the fiberglass with the wrap self adhesive to keep it closed. And some high temp. 3m tape.
http://www.google.com/search?q=fiber...&tbm=isch&sa=2
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Change in pipe diameter at water heater blacksheiladog Plumbing 2 03-06-2009 12:12 PM
Bestion solution for insulating a 2" hot water pipe ? Wookai HVAC 14 01-15-2009 06:59 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
