Insulating Flex Duct Or Ductboard? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 03:44 PM   #1
Rewards Points: 214
Insulating Flex Duct or Ductboard?
I asked this question a few weeks ago but only received an opinion, otherwise non definitive.
Can you add additional insulation to your existing flex duct or ductboard?
One posted opined in stating he thought you could. I've since added some faced r19 insulation to the top of my ductboard runs and will eventually add some to the sides. Otherwise, I will add more Cellulose insulation which already covers portions(bottoms) of my existing ductwork.
Anyhow, I came across a site that states you should not allow insulation to cover flex duct (see #8).
Is this really an issue or can I further insulate my ductwork?
Thanks for the input.....
Ralph III is offline   Reply With Quote
Old 04-27-2012, 04:56 PM   #2
An old Tradesmen
Rewards Points: 6,500
Works best if you use a face wrap, instead of an open insulation.
If flex is going to be intentionally covered with blown insulation. Cellulose is better, as it slows air movement down better. And will carry/permit less moisture to penetrate toward the duct.
Old 04-27-2012, 06:07 PM   #3
Rewards Points: 214
Hey Beenthere.
Can you elaborate a little more on what your saying? Also, are you recommending such as THIS refective type insulation for ductboard?
I have about 50ft (two branches) of main supply ductboard with flex duck coming off of those for individual ceiling registers. I had two large rolls of faced r19 insulation that I just rolled onto the tops of the ductboard. A portion (bottoms and partial sides) of all flex duct is already covered with cellulose blown-in insulation. I had thought to completely/mostly cover all ductboard and flex duct in cellulose insulation in hopes of raising r value.
What are the issues with this? Am I creating an issue in which moisture would collect on the ductwork because it would seem to be the opposite? BTW, I used faced insulation because I have quite a bit of that on hand.
Thanks, Ralph
Old 04-27-2012, 09:55 PM   #4
An old Tradesmen
I was referring to fiberglass with a foil face. But that should work.
What the article was talking about. Was the possibility of the flex duct getting cold enough for the moisture in the insulation to condense. Non faced insulation can breathe, and the moisture will condense sometimes.
Using flex duct for return. lakeresident HVAC 3 11-14-2011 10:56 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Jenn-Aire Downdraft - OEM flex duct required? Dwizzo Appliances 0 10-09-2010 05:35 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
