Insulating Exposed Roof Top Duct Work - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 12:59 AM   #1
Insulating exposed roof top duct work
Part of my house has an add on with a flat roof. My central AC system is roof mounted. Part of the output is directed to the ducts for the "main" part of the house though a down draft configuration to the ducts. But the part to the add on with the flat roof, is though round ducts running exposed on the roof from the side of the AC unit to the two vents for the add on to the house. In summer I know the ducts are getting an extra heat loud.
What is a way that I as a DIY'er can add insulation to those ducts. They are "insulated" on the inside, but it is not much, and I'm in a very hot climate
Keep in mind they are exposed to the wind, rain, and so on.
Moving the ducts inside is cost probative.
tom1336 is offline   Reply With Quote
Old 07-30-2012, 07:02 AM   #2
You can always build a "roof" over them to protect them from direct sun - just a metal roof that is raised off the ducts a few inches, which allows some airflow and such.
Or you could box them in, and insulate the box. That would be the best way, most likely.
Either way, if they're wll insulated and well sealed, I'm not sure how much benefit you'll gain from this.
scottmcd9999 is offline   Reply With Quote
Old 07-30-2012, 03:14 PM   #3
High winds (45 to 95 mph) around here make "shading" them unworkable, as the cover would get torn off the roof, unless it was extremely substantial.
I have thought about building a box and insulating he inside of the box, but I am wondering if there is some add on insulation that works in an outdoor environment, other then say spry on closed cell foam.
Old 07-30-2012, 03:22 PM   #4
Is it kosher to sleeve them inside larger duct?
Evstarr is offline   Reply With Quote
Old 07-30-2012, 05:04 PM   #5
Yes, the "roof" would need to be secured to the structure. We generally make 3 sided ducts around stuff like this (two sides and a top) and secure it to the structure.
We've also installed standard duct wrap and sealed it with several layers of roofing tar. It's a big mess, and I wouldn't do it for any big jobs.
Old 07-30-2012, 06:12 PM   #6
They also make sheets of dense foam rubber for that. Never put any on myself but have been on plenty of roofs with it on the duct. It's coated with a shiny tin foil looking substance that has an adhesive backing. Sorry don't know the correct names of the products for you to look them up,just saying it's out there.
Old 07-30-2012, 06:33 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
you can also contact an insulation company and they can spray foam the duct work and then the foam is painted white.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Insulating a flat roof with a pitched roof over Aarone1972 Insulation 15 10-26-2013 08:45 AM
Old Slab Duct Work Handy DIY HVAC 5 02-02-2012 09:06 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Flat roof insulating danomac Roofing/Siding 4 09-04-2010 10:43 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
