Insulating Existing Walls On Concrete Bldg - HVAC - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 03:57 PM   #1
insulating existing walls on concrete bldg
I live in a concrete condo and the front of our building stays very very hot. Other people in these units have replaced their ac units but it still is hot in the front of the bldg. I think if we insulate the front walls with some sort of spray foam...behind the drywall by drilling and filling in behind the drywall or even placing foam boards over the drywall to add extra insulation in the front rooms. Any suggestions??
lkparlato is offline   Reply With Quote
Old 08-03-2011, 05:55 PM   #2
Cut a piece of drywall out and see what's in the wall for insulation. For sure no foam board over the drywall since that's a major fire hazard.
Old 08-03-2011, 06:03 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 382
Ditto. you got to be careful what type of insulation you use or how you tear into walls. there are codes for fire separation between condos which you cannot alter by opening up walls and ceilings and using materials that do not give off toxic gases in a fire and harm other condo residents who may then sue you. may want to talk to your local bldg inspector/codes dept.
Old 08-03-2011, 06:59 PM   #4
insulating walls on concrete bldg
How about blown in foam?
Tags
air circulation , air conditioningir ducts , cooling , insulation upgrade
Insulating above grade concrete wall jhedger69 Building & Construction 6 07-23-2010 08:06 AM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 06:27 PM
painting basement concrete walls ctkeebler Building & Construction 6 11-17-2009 03:23 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
