Insulating Ducts... Did I Do This Right? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 11:21 PM   #1
Rewards Points: 105
Insulating Ducts... Did i do this right?
I wanted to insulate my heating ducts, since our unfinished basement is cold and resulting in heat loss. I used face batt insulation, with a mesh type unfaced side that keeps the insulation tight.
Directions didn't help about putting it on heating ducts. Also, what is the best way to put the hangers on? I tried pushing up from middle, but it'd "flip" after a minute, bow down, then spring out. I then tried putting one side 1/2 way up the joist, then slightly bending the other side to fit in. It worked, but it seems the slighted movement can knock one out or even start a mini chain reaction.
FYI I put a picture of the model number of the OwensCorning insulation I used.
Thanks,
Jdm
jdm001 is offline   Reply With Quote
Old 01-24-2011, 05:51 AM   #2
DIY staff
Rewards Points: 7,174
That looks good to me--but I'm not a heating guy.
One suggestion--if the spring wires aren't up to the job----use the sheet metal supports designed to hold duct work.
They are in the ductwork section of the hardware store--about 1" wide about 16 " long--held in with screws-----------And cheap----------Mike--
Old 01-25-2011, 06:34 AM   #3
Rewards Points: 105
FYI for anyone searching in the future, I found a phone number and called their support line. They said that if the temperature is 200 degrees or less, it'll be fine.
Since my room extensions off the main duct are all about ten feet away from the furnace, I'm good.
Also, the expert said as long as the paper face isn't touching anything, even excessive heat won't burn up... It will break down the fibers of the insulation over time, and there would be no fire danger unless it broke down enough so that the paper was touching the duct.
Jdm
The Following User Says Thank You to jdm001 For This Useful Post:
oh'mike (01-25-2011)
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
insulating the inside of square ducts zootjeff HVAC 7 07-10-2009 07:53 AM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 04:26 PM
