Insulating Duct Work Condensation Prevention - HVAC - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 10:18 AM   #1
Insulating duct work condensation prevention
I've found most "insulating duct threads were in ref to conservation of heat loss/prevention.
Im currently finishing my basement and I am going to insulate the duct work specifically to prevent condensation from AC in the summer and heat in the winter.
Walls and rim joist are insulated with 1" foam board.
I live in NJ.
My question is...
On most of the duct work I would only be able to cover 3 sides of the duct work with fiberglass insulation due to the positioning. Is that sufficient or will condensation pool on top of duct(the side I would be unable cover)??
If not, Should I spray foam the ducts to insulate?
Basement gets very cold when running AC and vise/versa due to leaks at seams which I plan to caulk or mastic.
FYI. I do not have any supply or return in basement. Should I cut one in? Furnace and coil are obviously in basement.
Thanks,
Stcrosby is offline   Reply With Quote
Old 06-08-2013, 04:01 PM   #2
biggles's Avatar
get a gallon of mastic brush on and paint all the seams on the ducting,anything that has cold air inside itself uninsulated will swet on the outside...but first seal all those seams and be liberal about it fan off let it cure...
Old 06-08-2013, 04:16 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Stcrosby View Post
I'm currently finishing my basement...
1) How do you define "finishing" if you don't have HVAC?
2) Duct in tempered (finished with HVAC) areas don't need insulation.
3) Mastic. It's a GoodThing.
Old 06-08-2013, 04:50 PM   #4
[QUOTE=TarheelTerp;1197601]1) How do you define "finishing" if you don't have HVAC?
I see your point.
Duct work sizing for 800 CFM unit mattorrell HVAC 11 03-25-2013 02:01 PM
Doing a dryer duct, the right way... nowwhatnapster HVAC 7 01-30-2013 07:52 PM
ECO / green options for insulating HVAC duct work ACtawk HVAC 3 10-03-2010 06:02 PM
Whole house fan using old soffit duct work zacman General DIY Discussions 11 06-19-2010 11:57 AM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
