Insulating Draft From In Wall Heating And Cooling Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2010, 08:51 AM   #1
Question
Insulating draft from in wall heating and cooling unit
Hi. I have an in wall Carrier Heating and Cooling unit (electric). Its fine when turned on...provides good heat and ac. When it is off, which is often in the winter the unit is very drafty basically letting the cold air flow right into the apartment. Question - are there any products (or creative ideas) on how to cover or insulate the unit while it is not being used to prevent this draft.
Any advice is greatly appreciated.
Thanks.
jor1228 is offline   Reply With Quote
Old 12-25-2010, 09:32 AM   #2
Some have a vent. make sure it's closed. Other then that all you can do is check the weather strip between the unit and frame.
Tags
draft , heating and cooling
need help with HEIL heating and cooling unit sendherastar HVAC 2 11-13-2010 02:49 AM
Upstairs unit not heating or cooling JakAHearts HVAC 5 06-13-2010 09:22 PM
heating & cooling small loft Master Brian HVAC 2 05-22-2009 11:09 AM
Heating and Cooling unit pauls HVAC 3 12-09-2008 08:49 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
