Old 11-20-2009, 12:31 PM   #1
Insulating basement ceiling - your recommendations?
Hello:
I am looking for recommendations from the forum regarding insulating an unheated basement. I live in eastern Canada - cold winters! I recently bought a small (approx. 1400 square feet) 2-story home (three years old home) that I will live in for a few years while I build my custom home. I would like to make my first floor floors (laminate and vinyl) warmer and increase the overall warmth/efficiency of the first floor (living room, kitchen, hallway). I am considering the following:
-- Insulating the basement ceiling with fibreglass insulation batts. The ceiling is open.
-- NOT insulating the basement walls - currently no insulation on the basement walls (i.e., no sheet Styrofoam)
Remember the basement is currently unheated and I will not heat it - it is storage space only
I only want to do one insulation technique in the basement due to budget (i.e., insulate the floors with batt OR insulate the walls with sheet styro)
My questions for you are:
Q1. Is my rationale right that batt in the ceiling will make the first-floor floors warmer/improve heat above MORE THAN doing the basement walls with styro sheets? My rationale is that batt in the ceilings is directly insulating the first floor floors whereas styro sheets ion the walls is indirect
Q2. IF I do the basement ceilings should I use R12 or R20? I read on a government website that they reco R12 but I think they assumed that the basement walls were already done with styro sheets
Q3. If I do batt the ceilings in basement, I know it will make my basement colder than it is right now but I don't care - it is only a storage space. But if I use R12 or R20 ceiling batts without the walls having styro, should I worry about the basement becoming so cold that my water pipes freeze? Or am I overworrying?
Thanks - great forum!
jtmann is offline   Reply With Quote
Old 11-20-2009, 04:29 PM   #2
Remodeling Contractor
I would not even bother with the ceiling. A basement stays about 60 degrees. What you do need to do is insulate with spray foam the rim joist and the area along that joist between every bay. 10% of the homes heat escapes here.
Old 11-20-2009, 05:24 PM   #3
Do Both not that much more and it's worth it.
SULTINI is offline   Reply With Quote
Old 11-20-2009, 05:35 PM   #4
Extreme DIY Homeowner
Scuba_Dave's Avatar
Are there water pipes in the basement ?
My basement used to dip down to 45, maybe lower due to poor windows & lack of insulation at the rim joist
Are the basement walls below grade, or above grade?
Big difference
Myself I'd insulate the walls
Especially if you will be selling the property in 3 years
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile (User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
Old 11-20-2009, 07:46 PM   #5
An old Tradesmen
If your basement is below grade. Insulate the joist spaces. If more then a 1/3 of it is above grade, insulate the walls. And as stated earlier, seal those rim joist.
Old 11-20-2009, 09:10 PM   #6
Most places would want you to cover any foam type insulation used on the walls with sheetrock as a precaution against deadly smoke that it will give if ignited.
meboatermike is offline   Reply With Quote
Old 11-23-2009, 07:38 AM   #7
One small addition to my origianl post:
Boy I am confused. I have been researching various owner builder topics for past few years and this topic of where/how to insulate a basement has the most varied opinions I have seen of any topic!
Btw an article in the July issue of The Journal of Light Construction that talked about unvented crawlspaces and different insulation methods: foam board on the crawlspace walls versus fiberglass batts between the floor joists. A testing company tested multiple homes in two different climates: Baton Rouge, La., and Flagstaff, Ariz. The study was looking at the energy use and humidity levels. Here was the conclusion: “To save energy, closed crawlspaces in warm climates should have insulation installed on the walls; in cold climate, the insulation should be placed in the floor system, even when ductwork is located in the crawlspace.”
Many conflicting sources it seems! Thoughts from the forum appreciated!
Hello:
Old 11-23-2009, 08:06 AM   #8
Scuba_Dave's Avatar
My last house I closed off the crawl space in the winter & insulating the exterior walls
The Temp went from down to negative number to staying around 45-55
My floor joists were already insulated & I did not take that out
Plastic on the ground to keep moisture out
Old 11-24-2009, 05:44 PM   #9
bump bump
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The schedule that you'll use when finishing a basement is very similar to the schedule that you'll use when finishing a home. In fact, it's almost exactly... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
This area. But if you feel like you want to do for insulation-wise, you can do this too. For insulation wise, too. 'Cause sometimes your walls, you know, certain walls like that back wall there...if you can't put nothing inside the wall you can put... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
Drywall ceiling in basement using floor trusses ralphfravel Drywall 10 04-03-2009 08:12 AM
Drywalling my basement ceiling luweee Remodeling 5 03-24-2009 07:58 PM
Insulating - Rim/Header Joist - Basement AndrewF Building & Construction 7 02-27-2009 12:10 AM
Insulating Cathedral Ceiling cholliha Roofing 3 11-25-2008 07:43 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
