Insulated Ducting Necessary? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 11:38 AM   #1
insulated ducting necessary?
I'm installing a fan in the attic to vent different rooms the inside the house. The ducting will run from ceiling boots in the rooms to an exhaust on the side of the house.
I've heard condensation can form inside the ducts in cold weather. Since I will be running the fan mostly on hot days, is insulated ducting really necessary in the attic?
deko is offline   Reply With Quote
Old 01-13-2011, 05:49 PM   #2
Yes it is. You won't be able to seal those vents off 100% in the winter. Cold will drop down and the heat will rise. Wont take long before the drywall around the vents is stained and the grills start to rust due to condensation.
Old 01-13-2011, 06:24 PM   #3
That is very true..here in the northern climes we use in floor supply systems.
We also have numerous boilers. Th AC in these homes is ducted thru the ceiling. The diffusers are a major heat loss path creating cold drafts.
I might add this is ranch style homes that have this problem.
Larger homes use what are called high pressure systems that don't incur the above problem. unico diffuesr
s
hvaclover is offline   Reply With Quote
Old 01-13-2011, 06:24 PM   #4
standard ceiling register
Installing Ducting for New Home Addition marshstate HVAC 12 07-19-2009 09:23 PM
Bathroom Fan - Do Insulated Exhaust Ducts Meet California Building Code? fritzycat1 HVAC 1 06-20-2009 02:29 PM
Bathroom Exhaust Fan Ducting drtpdee HVAC 1 03-03-2008 06:47 PM
Water in Furnace Ducting sdoca HVAC 3 09-14-2007 06:54 AM
Upgrading can lights to insulated? juliejules4 Electrical 2 12-03-2006 04:25 PM
