Insulated AC Pipe Freezing Up - HVAC - DIY Chatroom Home Improvement Forum
Old 06-13-2010, 07:42 PM   #1
Insulated AC Pipe Freezing up
Hi guys,
I've searched the forums here about this problem, and I just want to make sure I've done all I can before I call a pro.
The A/C works fine, then the insulated pipe that connects to the furnace freezes up after a while and I have to shut the a/c off and let it thaw.
I've cleaned the outside units fins as best as I could (with the hose) and I've made sure that the furnace filter is fresh. When the AC is on, it's blowing thru the vents properly, so I don't think its the blower motor.
Is there anything else I should try myself before calling a tech?
P.S. - I did notice that the old furnace filter had been facing the wrong way. I'm not sure if this could have messed something up.
Any help would be great,
Thanks!!
Upnya is offline   Reply With Quote
Old 06-13-2010, 08:18 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 398
If you can get at the underside of the evaporator coil in the furnace or air handler, check it for dirt and clean it. Otherwise the unit may be low on freon and need a Pro to check it.
Old 06-13-2010, 09:02 PM   #3
low on freon, needs to be serviced!
TLick1978 is offline   Reply With Quote
Frozen Vent Pipe Ratchye Plumbing 55 01-17-2017 05:21 PM
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
sewer pipe smell when weather is below freezing ltj Plumbing 4 12-17-2009 02:24 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
