To Insulate Or Not (Flex Duct) - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 09:16 PM   #1
Question
To Insulate or Not (Flex Duct)
Hello All,
From the postings I've seen already it looks like this will be an easy one for some of you out there. I'm finishing my basement in my one year old home and was wondering if I needed to use insulated flex duct. The ductwork that exists in the basement already, feeding the first floor, is insulated. I'm assuming that's only because the basement was unfinished. Is this correct? Can I get away with using uninsulated flex to feed the basement from a dedicated unit in the basement.
Thanks in advance,
Eric
BasementDweller is offline   Reply With Quote
Old 07-21-2008, 09:03 PM   #2
Hi Eric, I'll try to answer, flex ducts biggest problem is installer error. If you use flexduct make sure there are no kinks twists, smashed areas or it is useless. Dont know were you are but we use uninsulated metal duct here[wi.] Some use flex if the runs are nice open, straight and clear. Flex is fine because it is insulted, but must be installed properly, good luck Victor
sparky2474 is offline   Reply With Quote
Tags
flex duct basement
Can I add insulation to a 6" flex duct? EE playing with HVAC HVAC 10 06-24-2008 06:07 AM
Flex Duct Reduction mwhiting0402 HVAC 3 11-03-2007 01:30 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 02:30 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 01:12 PM
