Insulate Dryer Duct In Unconditioned Space?... - HVAC - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 08:49 AM   #1
Insulate Dryer Duct in Unconditioned Space?...
I just finished having a home inspection on one of my investment properties. The home inspector recommended that I insulate the dryer duct going through the crawl space with a minimum R-7 insulation. Is this correct?
DIY2009 is offline   Reply With Quote
Old 04-22-2012, 09:28 AM   #2
Rewards Points: 616
is the crawl space heated...
carmon is offline   Reply With Quote
Old 04-22-2012, 09:49 AM   #3
An old Tradesmen
Rewards Points: 6,944
If the space isn't conditioned, the water vapor in the vent will condense and clog up the vent.
Old 04-22-2012, 10:38 AM   #4
It's unconditioned space. Home Inspector's view was that it would create condensation.
Old 04-22-2012, 10:57 AM   #5
Rewards Points: 616
he is right ..a drier vent is a moisture duct ... the water vapor will freeze and plug the drier vent... I dont like them run in un conditioned spaces... insulate the heck out of it .. or relocate it if possible..
Rubber Dryer Duct khildahl HVAC 1 12-17-2010 12:19 PM
Flat dryer vent code??? duct Chemist1961 Appliances 3 10-24-2010 04:49 PM
Dryer duct not hooked up! happytroutman Building & Construction 7 04-18-2010 03:05 PM
Using existing duct for dryer and fan in basement.. faromic HVAC 3 03-10-2010 06:12 PM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
