Installing Wood Stove - HVAC - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 10:46 AM   #1
Installing wood stove
I bought an englander 13nch wood stove and am installing it this week. I am in the process of building the hearth and am thinking about the wall. I want to keep the wall clean and not install tile like most people do. I've seen people install it without the tile like in their living room. Can anyone give me the requirements if I want to install it that way?
johnsorious is offline   Reply With Quote
Old 08-21-2013, 08:44 PM   #2
Rewards Points: 944
What is your existing wall?
What do the destructions call for?
Do you plan on carrying insurance on the structure this is installed in?
If you plan on carrying insurance, then this is a real game changer.
cleveman is offline   Reply With Quote
Old 08-21-2013, 11:21 PM   #3
Rewards Points: 242
Check with the local building dept for the building codes.
They will tell you what needs to be done and what will pass codes. Around here the flue pipe has to be triple wall stainless
hvac instructor is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 09:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
Wood Burning Stove Pipe Question jh756 HVAC 1 08-20-2010 02:19 PM
wood stove insert Karpol General DIY Discussions 5 11-25-2007 11:56 AM
