In the house I just bought there was a wood stove previously installed. I just purchased a new stove and will install it whenever I have free time. How would I hook it up? I took a look down my chimney when I was on the roof installing a bathroom exhaust fan. The roof is seperated in half and their is a metal duct coming up for the boiler and the other half is for the wood stove that was previously installed. Would I have to install pipe in that other half of the chimney for the wood stove?
You would need to check with your building inspector as to local regulations. In my town, when I installed my wood stove, I needed to install a stainless steel liner in the half of my flue to be used by the stove. And I needed a permit. Failure to obtain said permit from the town could have resulted in serious trouble with my insurance company, who required proof that the installation met town standards, else they would have dropped my coverage.
I looked at the specs---you need a fresh air intake--6"
and a 6" flue----have you checked out how you will get a fresh air intake to the unit?
What is your flue size? To large is as bad as to small--a fireplace flue is often to large for a stove---sounds like you need to talk to the manufacturer---My heating supplier has an engineer on staff that gets me the information---Mike----
My chimney is split into two halves just like this. It's 5"x5". Can I just hook up my wood stove vent to this? This was where the old one was installed in the family room
The ancient adage of R. T. M. applies here. (Read The Manual)
It gives you the minimum sizing of the flue (your chimney whether it be lined with terracotta or stainless steel) and how to properly install it. They also suggest a stainless steel liner, but if your current flue is approved then you can use it as long as it is in good shape.
Combustion air intake is only required on mobile home applications but suggested for other applications. I would take the suggestion and add it, but you don't have to. It is always best to get your combustion air from outside the home because if you are replacing windows, insulating, caulking up all the gaps and cracks, you can potentially starve your fuel burning appliances for air. This can cause serious and potentially dangerous conditions. You can do what you want but I know what I would do.
My caveat for the manual is that on the manufacturers site they do not have your model listed and only give the model 13-NC which says it covers all of that product line post-2004. Your manual MAY be different so be sure to read it before you install anything.
Is the air line required? My wood stove is located in such an awkward place that I don't know where to put it without making it look bad. There was a previous stove installed and I plan to reuse that hole in the chimney for the flue.
Short answer: Yes. However, that's going to be totally up to you. The manufacturer is very specific in the manual, and your insurance company may require it as well.
Scroll down and read pages 11, 12 and 13 in your manual, it states, that an outside air intake is required in mobile home or basement installations. Additionally, it's reccommended for all home installations, especially if your home is airtight. Without a fresh air intake, it will use the air in your house to burn. This may cause the flame to burn sluggish and have a constant smell of smoke in your house.
Your stove has a 3 inch outside air intake located on the back of the stove for this purpose. IMO, and with the interest of safety in mind, I would try and find a way to get fresh air to your stove somehow.
All the above members have made great points and given you sound advice. Let us know if we can be of further assistance to you. Thanks.
I only ask this because my chimney is almost in the center of my house. I don't know how to run the fresh air intake without making it look bad. I want my wood stove installation looking as clean as possible. I'll draw out a floor plan tomorrow.
Here is a diagram of the lower level of my house. It's a ranch style home. The red arrow is where the previous wood stove was installed that was taken out by the renovator. I plan I putting my new stove in the same spot since the hole is cut out in the chimney for it. My chimney is split in two. It's roughly split into two 6"x6" squares. The blue box is where my hwbb is installed. As I said before my chimney is separated in two so the wood stove and hwbb exhaust won't interferre with each other. A photo of what it looks like was previously posted. Any ideas of where to install the air intake? I'm trying to keep the setup look nice.
Also would I have to run pipe in my chimney for the exhaust since my chimney is already 6"?
John, in your drawing, it's too bad your boiler room wasn't in a basement it would make it easier with a very low profile. However, is it possible to go through the wall where your stove will be sitting without interferring with your chimney draft. Your 3 inch air intake is located on back bottom of stove and there will be a very small portion of pipe showing in your living area. Just an idea, is it possible to get it through the wall somehow, and run it through your boiler room (up high so you won't run into it) to that outside wall without it looking like something from outerspace? The pipe would be a little smaller than your exhaust for dryer. The instruction sheet for the air intake kit says it should be as close to the stove with the least amount of run as possible. See instructions for kit.
I see what your up against. It's a tough one. I agree, you may not be able to do it without it looking like something from mars. Is your home air tight? (new home, new windows, all sealed up, etc.) Stay tuned, let's see if someone else can come up with some more ideas for you.
You would need to install a liner in the chimney flue if one or more of these factors applies:
1) The chimney is not rated for wood stove combustion gases
2) Your local jurisdiction requires a liner
3) Your insurance company requires a liner
4) The wood stove manufacturer requires a lined flue
I have a two flue chimney, similar to yours. My local jurisdiction required a stainless steel liner as part of their permit and inspection process. You might want to check with your local jurisdiction. As I have pointed out, installation without a permit may have negative effects on your home insurance policy.
My home isn't air tight I guess because everything except the boiler is original back to 1969. Hopefully someone will have a good idea where to run my air line.
Here's another idea: I don't know if it will work or whether you can do it. Just a thought. But it's better than nothing at all. In therory it sounds good, but may not be practical.
Can you get more fresh outside air into your boiler room (open windows, install a couple outside vents with louvers or screens to keep out pests, etc.)? Then just go right out the back of your stove to your boiler room and be done with it. It would be a very short run and low profile as well. You could dress it up with a nice looking pipe cover on the stove side and nice looking grate on the boiler room side. However, you would have to bring more outside air into your boiler room somehow for this to work. Because you have a boiler, hwh, and now wood stove all competing for the same combustable air. In the winter, all three will probably be running at the same time at some point, keep that in mind. Furthermore, going with more than 10 feet of pipe to get fresh air is defeating the purpose anyway. Should be a short run and close to stove as possible.
There are many very knowledgeable members here with years of experience. Maybe we can do some brain storming here and get a few more ideas for you to think about.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
