Installing Wall Ac Tomorrow - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 11:11 PM   #1
Rewards Points: 874
Installing wall ac tomorrow
Having a 25k btu wall ac installed tomorrow. Any tips regarding the framing etc. or something to install that can help reduce the noise, rattle etc.? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 07-21-2013, 02:10 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
not much you can do on a window unit.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 07-21-2013, 06:37 AM   #3
Rewards Points: 874
Its a wall not a window?
Old 07-21-2013, 06:43 AM   #4
An old Tradesmen
Rewards Points: 6,476
Usually, if its a name brand unit. Its construction quality is better, and it doesn't make a lot of noise.
Not a lot you can do to make them quiet.
Old 07-21-2013, 06:47 AM   #5
Rewards Points: 874
Ok thanks. What about when installing the sleeve in the wall? Anything special we should do or make sure of?
Old 07-21-2013, 07:22 AM   #6
An old Tradesmen
The hole should be made as small as possible, but yet that the sleeve slides in fairly easily. And a strip of weather proofing can still be stuck in(helps minimize noise potential).
All in all, its a pretty straight forward thing to do.
Old 07-21-2013, 08:31 AM   #7
kwikfishron's Avatar
Rewards Points: 176
Is this a load bearing wall? If so you'll need to do more in terms of framing than just cutting a hole in the wall.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
oh'mike (07-21-2013)
Old 07-21-2013, 10:17 AM   #8
Rewards Points: 446
The hole you make should to be framed the same as you would for installing a door or window.
old_squid is offline   Reply With Quote
Old 07-21-2013, 10:54 AM   #9
Rewards Points: 874
Thanks starting the install now.where does the weather stripping give exactly? Thanks
Old 07-21-2013, 11:21 AM   #10
An old Tradesmen
Around the sleeve.
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 05:56 PM
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 10:48 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Help installing A/C in apartment wall Cop J HVAC 9 04-20-2012 07:19 PM
Installing tile over uninsulated wall? phillyskyline Building & Construction 8 09-21-2009 07:20 AM
