Installing VisionPro IAQ - Need Help - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 04:06 PM   #1
Rewards Points: 150
Installing VisionPro IAQ - need help
Hi - my deisre to install a whole house humidifier and monitor/adjust RH from the thermostat snowballed into buying a Honeywell VisionPro IAQ thermostat. Overkill but I hope to grow into it. I am having trouble with the wiring. Current system:
Goodman SSZ14 heatpump
Goodman AEPF Air Handler
Honeywell Chronotherm III t-stat with manual heat/cool changeover (circa 1991)
Current system is wired as follows (first photo) and doesn't follow any of the diagrams I have. Trying to figure out how to wire it correctly and looking for advice. Second photo is the diagram I think I should be working from. Thanks! and I apologize for the crude drawing.
silversport is offline   Reply With Quote
Old 02-04-2012, 05:25 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
What make and model humidifier are you installing? Do you also want dehumidification with air conditioning enabled?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-04-2012, 05:37 PM   #3
Rewards Points: 150
I can't thank you enough. Humidifier is an AprilAire 600. No plans for dehumidification right now.
Can you provide insight into the to current wiring? Just to satisfy my own curiosity?
Thanks.
Old 02-04-2012, 05:43 PM   #4
AKA HVACTECHFW
current wiring is for the current thermostat requirements and its internal operation. New thermostat uses different internal operation.
IT IS WHAT IT IS
Old 02-04-2012, 06:01 PM   #5
Rewards Points: 150
Geez, I think I just realized what was confusing me. Lower left of my hand-drawn looks to have four wires (Y1, YCON, O, W2) jumped together. They are actually bundled at the end with electrical tape. I was thinking that was lazy work but now realize it's likely unused wires bundled together. That really clears this up.
Thanks again for the assistance.
Old 02-07-2012, 06:56 PM   #6
Rewards Points: 150
The AprilAire 600 humidifier came with a 24V transformer but I assume it's okay to tap into the AH's existing 24V transformer?
Old 02-07-2012, 07:25 PM   #7
AKA HVACTECHFW
I prefer to have the humidifier on it's own circuit. The reason for this is so that if the humidifier circuit were to fail due to a bad wire or failed solenoid valve it would not cause the heat or air to not work as well.
IT IS WHAT IT IS
Old 02-11-2012, 11:47 PM   #8
Rewards Points: 150
New IAQ and humidifier installed; and everything is working. Thanks again for the assistance. I was working within the confines of a previously-installed humidifier (location and bypass routing).
Old 02-12-2012, 11:27 AM   #9
AKA HVACTECHFW
glad you got it going! Good job
IT IS WHAT IT IS
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 10:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 12:11 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
