Installing A Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 02:26 PM   #1
Installing a thermostat
Recently, I had a technician look at my HVAC system which was on the blink. He said it was due to a short which he fixed and I also needed a new thermostat. Unfortunately he didn't have any on his truck (Which according to him would cost about 200.00 anyway) and said I could buy one at Lowe's or Home Depot for a lot cheaper.
He said to get a 1 heat/1cool thermostat.Which I did and when I hooked it up nothing is happening. I'd rather not have to call someone else out there and have to spend a lot of money which I don't have. Any suggestions?
machx7 is offline   Reply With Quote
Old 05-31-2010, 03:34 PM   #2
Check for a blown low voltage fuse or burnt out transformer.
Old 05-31-2010, 06:24 PM   #3
Marty,
The guy checked and supposedly replaced the blown fuses.He hooked the wires up to a device before he left and it came on.
Matt
Old 05-31-2010, 06:45 PM   #4
If you didn't turn the power off before insalling the new thermostat there's a good chance they're blown again.
Old 05-31-2010, 08:26 PM   #5
Hmm I actually did turn the power off before installing. Is there anyway to hot wire the damn fan so it will cut on?
Old 05-31-2010, 09:08 PM   #6
GC/Master Plumber/Mech
Rewards Points: 560
Jump the R and G for the fan
Also, depending on the age of the furnace on the front of the case doors there should be a clear plastic glass sight hole. If you look in the hole do you see a flashing LED. If you have a sight glass and no visible LED then power has not been restored.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 05-31-2010, 11:52 PM   #7
Ok here's a real stupid question....what do I jump the R and G with?
Old 06-01-2010, 01:37 AM   #8
biggles's Avatar
scrap stat wire ..paper clip..check your new stat might need C connected so you have a 24V power source to power the LED electronics within..if it is lit but no action could be lookin for that C which is the other side of the TR in the furnace..if you get fan on the jump you have 24Vs at least.
Installing new thermostat, getting no response fupafupa HVAC 3 05-25-2010 02:01 PM
Help Installing Honeywell Thermostat.... jobondur HVAC 14 03-30-2010 10:01 PM
Installing new thermostat Jarhad HVAC 1 02-28-2010 02:39 PM
Installing a wireless thermostat BPH HVAC 4 05-27-2009 12:37 PM
Need Help Installing New Thermostat !!! twadd10 HVAC 1 02-05-2009 11:24 PM
