Installing Split A/c System - HVAC - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 03:09 PM   #1
Installing Split a/c system
I bought a new 2 ton split system that I am installing in my shop. It comes with a 25' line set. If I cut & make lines shorter do I need to have freon removed from system as it is charged for the 25 feet? I have the vac pump but not a reclaimer.
Thanks Randy
RDH1958 is offline   Reply With Quote
Old 07-31-2011, 04:20 PM   #2
An old Tradesmen
Rewards Points: 7,400
Generally, yes.
Old 07-31-2011, 04:31 PM   #3
Is there any disadvantage to using the origional length. Is the shorter better in this case?
Old 07-31-2011, 05:29 PM   #4
An old Tradesmen
10 foot difference on that short of a line will make no difference in efficiency or capacity.
Old 07-31-2011, 05:45 PM   #5
Thanks for your reply
Old 07-31-2011, 06:57 PM   #6
REP
As long as you set it up to super heat and / or subcooling.then you're good to go.
REP is offline   Reply With Quote
Old 08-02-2011, 08:26 PM   #7
Shop is now cool. Now I need to get the line set coverd up!!
Any suggestions??
Old 08-02-2011, 08:46 PM   #8
An old Tradesmen
http://www.calibex.com/Line-Set-Cove...0--search-html
The Following User Says Thank You to beenthere For This Useful Post:
RDH1958 (08-04-2011)
Split System Replace, Resell? golddog HVAC 3 06-25-2010 03:38 PM
Installing a New Central Air System vdu HVAC 7 09-01-2009 03:45 PM
Sanyo split system Larry C General DIY Discussions 1 04-03-2009 04:47 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 05:23 AM
