Towards the end of dec ill be installing a radiant heat system. This coming week a representative from .radiantec.com will be calling me so i can get a quote from them. What are some things i should be looking out for or questions i should be asking. I do not know alot about radiant heat.
Heres the project.
Mater bedroom roughly 480 sqft.
3/4 t&g plywood (plywood not OSB) subfloor, quartersawn Oak Hardwood and Tile finish, joist are 11-7/8 TGI's spaced 12 on center and 16 on center with two LVL (3-1/2 thick) beams to be crossed..
Current house is 800 sqft.
Boiler (Peerless Pinnacle PI-80 (REV1)) and central air, air handler/heater coil in atic.
Hot water is held in new hot-water holding tank heated by boiler.
For the project....
What would a good heat source be ?
House has NG.
Currently have a Peerless Pinnacle PI-80 but that will be sitting about 40' away from the floor which will be heated.
Plan on getting a small tankless for the project to supplie hot water to a single master-bath (will have two shower heads) but thats it.
Should i get a bigger tankless, can the PI-80 handle the 40' hike ?
Attaching the pex to the floor?
Read about this in two different ways.
One way uses plastic 1/2 round fasteners that are nailed up
Second is staples and that allumeno heat reflector.
Would it be wise to glue and staple the reflector sheet ?
As time goes by and more questions pop into my head and more information is learned, ill post it here.
The boiler should be piped primary/secondary, then hte 40' doesn't matter.
Next, you need to know how much heat your current set up really needs, to determine if the boiler can handle the increased load.
You need to do a load calc on the addition to see how much heat it needs, to know if you can get enough radiant heat to heat it.
Your radiant supply should be able to determine what water temp you need, and if you need a second source of heat for design conditions.
Do not try and use temp set back with a radiant system.
Can you explane what you mean for both of those ? I dont understand.
I can sweat pipes, run lines, etc. but know nothing about heat sources or how they work.
it sound as tho you will be installing this system under your subfloor. you will have to contend with the flooring cleats or staples that are sticking through the floor.
Yes from under. I havnt installed the oak, was gonna do that last. The plan, snap chalk lines under the subfloor to make sure the pex is run nice and strait, then snap red-lines on the top NOT to nail and blue lines where all the joists lay to make things go alittle easier and safer (not to nail any pex), if that a wise thing ?
Did alittle reading on a radiant site and they said for new installs its best to have the radiant system runn for alittle while to dry out the subfloor of any moisture, which im sure i have been the subfloor got wet from teh rain a few times durning construction.
it sound as tho you will be installing this system under your subfloor. you will have to contend with the flooring cleats or staples that are sticking through the floor. I did this system to my house, and no mater how you fasten the heat transfer plates to the underside of the subfloor your going to be hearing the plates expanding when they start to heat up. but the comfort out ways the 4 minute noise. Good choice with the 1/4 swan oak. the heat will rise much easier and less movement with the flooring. BOB
Just read your post about only using one fastener....my crew totaly didn't do this and I wake up every morning to the noise of a really bad troop of boyscouts tap dancing under my bed!
I have 3 systems on my home. In cement in the basement, staple up with the noise issues on under the 130 year old fir floors in the joists and the "warm boards" in the attic.
The heat is GREAT...the noise not so much.
The basement ceiling is still open right now and I am trying to figure out insulation. I read the other post about the plates not staying on with one fastener and think that would be the case here too.
Any advise? I can still remove them but I paid BIG BUCKS to have them and my installers have told me that I wanted the plates and I got the plates and too dang bad it they make noise...... so much for customer service??
Oh well I have to decided what to do from here. Do I remove them before I close in the ceiling? Do I leave them enjoy the heat and get used to the start up noise? Do I take some staples out and see if just hanging there not snug to the floor is quiet?
they where the single tube type. for 1/2" pex. and I believe they where 18" long. one fastener would not of worked. the weight of the pex pulled the plates away from the subfloor. so i used 6 3/8" long crown staples per plate 2 @ each end and 2 in the middle. this was back about 8 years ago. They did come along way with there technology. plus the fact I grounded down all the flooring nails that where in the way of the plates,which I was worried about having the floor buckle. but 8 years latter still as new. BOB
Temp set back. If you lower the temp during the day when your not using the bedroom, and try to raise it for sleeping. It could take several hours to recover 4°.
But if I use just one the plates would hang down as they are long like the other person posted about. The crew who installed it did change some over to sheet metal screws but it didn't help with the noise. I think the noise comes from the tube expanding in the plates (is that right?)
thanks so much for your help with these questions!!
I have tried some different approaches to securing the plates to the underside of the floor, I even Ripped and installed 1/4 Luann plywood to the underside of the sub floor, using one edge of the ply to support the pan and stapling the other to the subfloor. And I'm Still getting the noise, As Beenthere suggested it appears that the noise is coming from the pex and the pan expanding.
Next time I come across this type of install what I plan on doing is rip 1/4" x 6" strips of ply and staple them to the underside of the pans and the subfloor, Sandwiching the pan between the ply and the subfloor.
My reasoning is that with the warm boards you do not get the noise being the pan is compressed to the plywood. BOB
Thanks everyone for your ideas. My warmboards too are nice and quiet. I didn't have that option for this floor though as it is the old exisiting 130 year old wood and I didn't want to cover it. I wonder if I used screws but didn't snug the plate to the floor or maybe screws with a rubber washer so there is a gap? Of course we are talking about 700 plates here......but we are also talking about a house I hope my great great grandkids will be living in someday... My kids are the 5th generation to live in it
Im gonna make my own "warm boards" (not really warm boards, but you will see from the thread there) soon, should the same apply, cooler temp water ? If so, how can one figure/calculate this out ?
I have the staple up system below the floor on the middle floor of my home. I also have it in the cement for the floor below.
My question is do I NEED to insulate with special insulation? I really don't care if the heat goes up or down as they are all living space.......I want to use some R30 for noise reduction but is that OK? It is a large house so there will be substantial cost to use the foil/bubble insualtion.
So is it worth the cost? Is it a must do? Is it a should do? Is it a.....well up to you if you do or don't
Radiantec sold me these really cheap (but not inexpensive enough) aluminum plates . . which they have since discontinued.
They're really thin.
Can these put up with only one staple?
Should they?
Thanks.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
