Installing New Thermostat Need Help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 12:33 PM   #16
HVAC / Plumbing
from what I can tell. green wire is on common terminal & yellow wire is on cool relay terminal. looks like blue wire isn't connected. You can wire it any way you want, but wires have to match from board to t.stat. Green wire is usually connected to g on board & g at t.stat & blue wire would/could be on c or you can use the yellow. what ever colors you use at the board for r w y c have to match r w y c at t.stat
kenmac is offline   Reply With Quote
Old 02-28-2011, 02:51 PM   #17
An old Tradesmen
Rewards Points: 7,384
Post brand and model number of your outdoor unit. Almost looks like you have a dual power source set up.
Old 02-28-2011, 10:58 PM   #18
HI All,
thanks for all the help, it did turn out to be a bad blue wire going from the wall to the furnace, got it replaced today and that solved the problem.
effusion_01 is offline   Reply With Quote
Old 03-01-2011, 05:09 AM   #19
Electrician
SD515's Avatar
Rewards Points: 504
Good to hear it was something simple.
Kyle
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Question on installing an Honeywell RTH6350 programmable thermostat. outdoorted HVAC 3 01-02-2011 06:48 PM
Heat Won't Come on After Installing New Thermostat joegaget HVAC 6 10-12-2010 03:12 PM
Installing new thermostat, getting no response fupafupa HVAC 3 05-25-2010 02:01 PM
Help Installing Honeywell Thermostat.... jobondur HVAC 14 03-30-2010 10:01 PM
