Installing New Thermostat, Getting No Response - HVAC - DIY Chatroom Home Improvement Forum
Old 05-24-2010, 09:40 PM   #1
Installing new thermostat, getting no response
I was recently changing the batteries on my old thermostat and accidentally broke one of the prongs off when trying to reassemble it. I bought a new thermostat and have followed the directions the best i can but I am getting no responses from it. I can't get air to come on either in heat or cool mode. I have even tried two different models of thermostat. Any advise?
fupafupa is offline   Reply With Quote
Old 05-25-2010, 06:17 AM   #2
Check the low voltage fuse in the furnace or air handler.
Old 05-25-2010, 06:36 AM   #3
where do I find low voltage fuse?
Thanks for the help on the topic. I have no earthly idea about how to find the low voltage fuse. Can anyone help?
Old 05-25-2010, 02:01 PM   #4
Check your connections. Is this a 2-wire? If so, connect the two wires at the thermostat end and see if the heater/AC turns on. If so, then your circuit is OK.
Now, look in the instructions for the thrermostat about connecting a 2-wire system (if this is the case.)
bobhood is offline   Reply With Quote
Help Installing Honeywell Thermostat.... jobondur HVAC 14 03-30-2010 10:01 PM
Installing new thermostat Jarhad HVAC 1 02-28-2010 02:39 PM
Installing a wireless thermostat BPH HVAC 4 05-27-2009 12:37 PM
Need Help Installing New Thermostat !!! twadd10 HVAC 1 02-05-2009 11:24 PM
Installing a new Thermostat jazzscreamer HVAC 4 12-22-2008 11:39 AM
