Installing A New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2008, 09:37 PM   #1
Installing a new Thermostat
I had a Honeywell non-adjustable thermostat in my brand new home. I've installed a new adjustable thermo and want to make sure I've connected everything correctly. Everything seems to be working well, but I'm not sure how this whole heat pump/aux thing works. When the heat kicks in, the air seems to be only luke warm if that, but if I crank the heat up 5 degrees or so the outside unit turns off and a few minutes later turns back on and then I get some nice hot air flowing through the vents. Is this normal? Please advise. Thanks!
Bob
jazzscreamer is offline   Reply With Quote
Old 12-21-2008, 09:40 PM   #2
Electrical Contractor
kbsparky's Avatar
That "nice hot air" you are getting is the result of the aux. heaters kicking in. Most heat pump thermostats have 2-stage capability, and when the set point is more than a few degrees different from the room temp, it will cause the aux heat to come on to make up for that difference.
Bottom line is you don't want that to happen unless you are prepared to pay a much higher electric bill.
Old 12-22-2008, 04:34 AM   #3
An old Tradesmen
Rewards Points: 8,154
Something isn't right somewhere.
The HP shouldn't shut off because you turned up the temp.
Old 12-22-2008, 09:26 AM   #4
If you gently turn up your tstat 1 degree increments over a long time does the HP stay on? It could be turning up your tstat 5 degrees is forcing the aux heat on, and once at set-point the HP takes over.
dac122 is offline   Reply With Quote
Old 12-22-2008, 11:39 AM   #5
Rewards Points: 129
Cranking it up more than 2 deg. will activate the aux. heat, however, when doing so the outside unit should remain running.
jeepgrady is online now   Reply With Quote
Installing a wireless thermostat BPH HVAC 4 05-27-2009 12:37 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
