Installing New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 03:53 PM   #1
Rewards Points: 160
Installing new thermostat
Hello I purchased my first home as of this week and there are a couple things I would like to change. I currently have the Robertshaw 9400 thermostat and Im going to replace it with the Ecobee smart si. I have a 1 stage furnace and 1 stage A/C. I cant figure out why the "Y" has 2 wires running to it? The reason I question this is because there has been some major wiring issue in the house that I have fixed already. I attached a pictures of the thermostat currently installed.
I just want to make sure I install my thermostat correctly without harming HVAC system.
word2yamutha is offline   Reply With Quote
Old 03-13-2013, 04:55 PM   #2
Unusual. I would say if both heat and cool are working properly then it's properly wired. Maybe take it off the wall and see if the wiring is spliced behind it, and then check the wiring at the furnace end to see where those wires map to and maybe you can figure out why you have 2 wires on the Y connection.
Burbman is offline   Reply With Quote
Old 03-13-2013, 05:05 PM   #3
Rewards Points: 160
Well I actually haven't tried the A/C in my house since its still pretty chilly outside. When I did a google search on this matter I bumped into the same issue this person has and they have the same thermostat as I.
Links to other DIY sites are not permitted.
I have a feeling they wired the Rc and Y to the "Y" terminal but Im not sure why. I close on the house this Friday so I'll have to take a closer look.
Last edited by beenthere; 03-13-2013 at 06:36 PM. Reason: Removed link to another DIY site
Old 03-13-2013, 06:04 PM   #4
If they did that your A/C would run non stop. Honestly my first instinct is the red wire under Y goes to your A/C unit. That is typically done in the furnace, but would work at the stat like that, except a second wire has to go to common, and I don't see another wire and no common would be available at your stat.
Take a picture of the low voltage connections inside your furnace and that may help.
Last edited by beenthere; 03-13-2013 at 06:36 PM. Reason: Removed link to another DIY site from quote
JScotty is offline   Reply With Quote
Old 03-13-2013, 06:06 PM   #5
Well as the guy in the link you posted found out, there was a reason they wired it that way. Just because it's unusual doesn't mean there is a problem, additional investigation is warranted before a course of action can be determined.
Old 03-13-2013, 06:37 PM   #6
An old Tradesmen
Rewards Points: 6,142
DIYCHATROOM Moderator team.
Old 03-13-2013, 08:25 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
The smart si thermostat requires a C connection at the thermostat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-14-2013, 12:06 AM   #8
Rewards Points: 160
Hopefully these are better pictures for a better clarification. I guess I got lucky knowing that I have a common wire connection. Im not sure what the white wire is that is connected to the common wire.
Installing new thermostat-20130313_221532.jpg   Installing new thermostat-20130313_220940.jpg
Old 03-14-2013, 12:13 AM   #9
AKA HVACTECHFW
The separate 2 wire loom goes to your outdoor condensing unit. The wire nutted blue and white wires will go to C on the new stat. All other existing connections transfer to the new stat.
IT IS WHAT IT IS
Old 03-14-2013, 02:17 AM   #10
Rewards Points: 160
Will the "Y" terminal be the same with the existing red and yellow wire?
Old 03-14-2013, 07:15 AM   #11
AKA HVACTECHFW
Yet it will be the same. Normally the extra wires are connected at the furnace control board. For some reason yours was done at the stat. No big deal.... just unusual
IT IS WHAT IT IS
Old 03-14-2013, 09:49 PM   #12
Rewards Points: 160
Just wanted to say thanks for all the great information. Here is the finished product.
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 06:35 PM
Installing a thermostat machx7 HVAC 7 06-01-2010 02:37 AM
Installing new thermostat, getting no response fupafupa HVAC 3 05-25-2010 03:01 PM
Installing a wireless thermostat BPH HVAC 4 05-27-2009 01:37 PM
