Installing New Lux Thermostat, Wiring Help Please - HVAC - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 02:12 PM   #1
Installing new Lux thermostat, wiring help please
So I've been trying to install a new programmable thermostat, but I'm having a heck of a time deciphering how the wires should be hooked up, and not one of the 5 wiring examples in the instructions seem to be for my situation, so I'm hoping someone here can provide some helpful input. I'm trying to replace a simple Honeywell thermostat with a LUX TX-500E on what I understand to be a 5-wire heat pump system (Goodman CPLE60-1C). I've tried a few different seemingly logical setups, none of which have worked, and I'm hard pressed to find any specs on this heat pump that can give me any guidance. Any help would be GREATLY appreciated.
2th Doc is offline   Reply With Quote
Old 09-22-2012, 02:38 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
there must be a jumper between Y and W same as on the old thermostat. Otherwise, the wires go to the same labeled terminals they came off of on the old thermostat. There should also be a jumper between Rc and Rh. C gets taped off and not used
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-22-2012, 02:40 PM   #3
Silly me, I didn't even notice that jumper behind the terminals on the old stat. You were right, of course. All is working now! Thanks so much!
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 02:11 PM
Installing new thermostat / wiring question roliemu HVAC 3 12-03-2011 07:48 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Thermostat to Controller Wiring Molson HVAC 1 07-05-2010 06:24 PM
Thermostat wiring question sob HVAC 11 10-21-2009 10:31 AM
