Installing A New Furnace, Shoud I Install An A/C Coil Now? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2008, 10:49 PM   #1
Rewards Points: 81
Installing a new Furnace, Shoud I install an A/C Coil Now?
Hello, Thanks for taking the time to read this and help someone else. I am installing a trane xr90 into my attic of my 1200 sq ft home in Southern California. I originally started this project with no intention of adding A/C. But now that I have the furnace ready to run except the duct system I am thinking twice about my decision. Any idea as to what size I would need and what effieciency I should be looking at. My furnace is a 60,000 btu which is a little oversized but the price was right. I was thinking of 2.5 tons but not sure. Typical temps here are around 85 degrees in the summer. Does that sound right for this size of house. And yes I know you can be forsure with out a load loss calc. Also how do I know which coil fits my furnace.
hartkem is offline   Reply With Quote
Old 11-10-2008, 10:31 AM   #2
If you are leaning towards an AC down the road then put in the coil. In almost all installs I put one in just because Al Gore has said we will be having global warming and everyone will need AC in the future.
Since you are doing the work yourself it is not more expensive to do it later but it is sure a lot easier to do it now. Or you could just build your plenum to take an A coil later and then just slide it in when you decide you want it.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
Cost of installing Attic Furnace in new construction marejw HVAC 3 01-11-2008 05:00 PM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 09:07 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
