Installing New Expansion Tank - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 01:20 PM   #1
Post
Installing new expansion tank
I need to replace my leaking steel expansion tank on my 175,000 btu output residential boiler. The existing tank is on the supply side, has a shut off to isolate it. Is it ok to install a new bladder type tank where the old one was? It would be in a dead end location but do have a float type air eliminator in the system. I can't install it as the diagram from the tank shows. My circulator pump is plumbed into the 1 1/2 pipe coming out of the boiler then goes to the supply manifold that make up the different zones and the offshoot to my old expansion tank.
ted schumm is offline   Reply With Quote
Old 07-19-2009, 06:01 PM   #2
as seen on tv
Rewards Points: 150
You should repipe the boiler. If going to return side add it before the circulator . tied in with feed water with reducing valve and back flow preventer. Install air separator on supply. There are other ways to pipe that may meet your needs, Best to have a pro evaluate what is best for you.
qbert is offline   Reply With Quote
Old 07-19-2009, 10:49 PM   #3
tk03's Avatar
Rewards Points: 150
If you are going to a diaphragm tank make sure you size it properly. That size boiler will require a larger tank and depending on the radiation maybe even larger yet.
tk03 is offline   Reply With Quote
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
how to install a expansion tank to a gas boiler iris Plumbing 2 10-08-2008 03:17 PM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 11:53 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
