Installing A New Boiler Expansion Tank - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 02:12 PM   #1
Installing a new boiler expansion tank
I have determined that my existing expansion tank has failed (The system is Wiel Mclane and is about 7 years old.) and will need to be replaced. There is no shutoff above the tank so I found the valve that feeds water into the boiler and is in the same line as the backflow valve and the reducer valve.
I have purchased a new expansion tank and also a valve to install above the tank so if this happens again I will be better off.
I understand how to remove the tank and add the new one but my question is - do I need to relieve pressure in the boiler before unscrewing the old tank? And also once the new tank is installed do I need to bleed air and add water that was lost in the replacement process?
Thanks for your help....
Ken
CoachDad is offline   Reply With Quote
Where to find an old boiler expansion tank? jrdamien HVAC 1 12-01-2009 08:08 PM
Installing new expansion tank ted schumm HVAC 2 07-19-2009 10:49 PM
how to install a expansion tank to a gas boiler iris Plumbing 2 10-08-2008 03:17 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
