Installing A New Bathrom Vent Fan - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 10:58 AM   #16
Just call me Andrew
Rewards Points: 1,020
I am thinking of using a powerful panasonc (240CFM or more) inline fan up in the attic to exhaust both bathrooms through the same hole in the gable wall in the attic. I'll use a "wye" connector to run two 4" ducts into the fan. Does this sound feasible?
Andrew
secutanudu is offline   Reply With Quote
Old 04-17-2010, 11:44 PM   #17
Secutanudu
I don't know if your done with the fan installation yet, but I installed a inline FanTech 100cfm with flex duct, ran it 20ft to a gable end wall for a 6'x10' bathroom, works fine.
I talked to FanTech they told me the fan is rated for 100' & would be fine running 20'.
I can hardly hear this fan running.
If you go with to much cfm it could draw to much air (back draft) thru other sources like the furnace & hot water heater causing a pollution problem.
It will also draw air from every crack & crevice in the homes outer shell thats not sealed.
kurtkrn is offline   Reply With Quote
Old 04-18-2010, 06:48 AM   #18
Just call me Andrew
Kurt - thanks. I will probably just install two fans, one for each bathroom. I plan to do it in a month or two.
I appreciate it!
Andrew
Need advise installing soffit vent scrupul0us Roofing/Siding 11 10-09-2010 07:57 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 10:57 AM
Installing range hood - wall vent DIYGST HVAC 3 01-04-2009 07:45 AM
