Installing Natural Gas Furnace In Place Of Heat Pump, Please Help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 01:35 PM   #16
Originally Posted by beenthere View Post
VS blowers, tend to get real loud on under sized duct systems.
How loud, varies with how under sized.
Along with noise. An under sized duct system also tends to decrease the life span of VS blowers. if its under sized too much.
Doubt the guy you talked to mentioned this either.
Since it has a VS blower, its a 2 stage unit then.(as I recall, Carrier doesn't have a 110,000 input furnace, could be mistaken though). Hmmm.
So you can wire it to just use first stage. This will be 65% of second stage firing rate. It won't be as efficient for the year. Nor provide the comfort 2 stage is suppose to. But, it will heat.
I figured my last post would spur up some heat...
I had to "jump" into this because I have tenants without heat and I don't have $6500 to throw into an already bad investment. But I don't blame anyone else for that.
I will post the model number in a bit after work. I have a carrier manual with numbers and dimensions, as well as a carrier installation guide. It doesn't seem like gray market to me. I figured it wasn't a currently available model since it was on sale, so i didn't bother checking carrier's web page to see if they still offer the same unit.
KlamathMog is offline   Reply With Quote
Old 10-20-2009, 01:52 PM   #17
I don't have the model number handy... but the unit came with carrier documentation and it had their name on the cover.
It installed relatively easily in about 14 hours (including assembly of the outdoor cabinet). Works fine, blows nice warm air inside!
Thanks for the help everyone!
Old 10-20-2009, 01:55 PM   #18
Found it on their webpage. It is a Carrier 58STA...
description/features match up too.
http://www.commercial.carrier.com/co..._SIT12,00.html
Replace Heat Exchanger or Furnace deccher HVAC 41 10-22-2013 08:45 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 03:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
