Old 06-04-2008, 09:53 AM   #1
Default Installing a mini split ductless system
I am thinking of installing a dual-zone ductless mini split system in a three-story town house. I was quoted $3,000 just for installation, around $6,000 together with the hardware, which I cannot afford. I am thinking of running the copper lines and mounting the condenser and evaporators by myself, and then hiring an HVAC contractor to handle only connecting the lines, because I'm afraid to screw something up.
I have never done anything like this, and have a few questions.
1. There will be a few tight spaces, through which I'll need to run the lines. Are the copper tubes flexible enough to just pull through a hole at an angle? Is it better to solder pieces together, perhaps, or do I need to keep the copper tube in one piece?
2. Do I run the lines first, and then insulate them, or insulate them first?
3. What's the best way to insulate the opening in the wall, through which the lines will be entering the house from the outside?
4. Do Fujitsu mini split units have a good reputation?
Many thanks in advance for any info!
agenkin is offline   Reply With Quote
Old 06-14-2008, 11:33 PM   #2
Default Mitsubishi
Is the more trustworthy brand make sure the lines are sized for each of the head units and if the lines are differnt sizes the right ones go to the right place the lines are very flexable and if you have to drill a larger hole to get it through with out brazing(solder is a serious code violation on refrigernt lines)you do the manufacturer uses flare connections and why risk the leak . pitch the lines and run 5/8 vynle tubing with the lines this is your drain and run 12/3 strainded direct burial wire you have to use strainded wire because the equipment cummunicates through the t3 terminal .Insulate both the suction and the liquid line together or seperate you do not have to insulate the drain and i find it easyier to insulate first
geo fan is offline   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk to you for a minute about split bats. What I mean by split bats is when you... Read More »
Proper Attic Insulation
Proper Attic Insulation by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. We talked about earlier how your insulation can become a filter essentially and if it doesn... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk here for a second about baffles. These are what we call baffles right here... Read More »
Hi, this is Jon, and in this clip we'll be identifying our problem. We have a couple different problems with our garage entry door. The first one is that it does not have the fire rating that we need it to have. The second problem is that when it was... Read More »
Hi, we are going to be insulating these walls. It’s an older house and we recently discovered despite our thoughts they are indeed not insulated in the walls. These walls are a little harder to tell exactly where the studs are. You can kind of... Read More »
Mini Split BillyD HVAC 4 06-14-2008 04:23 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 07:23 AM
Mini split heat pump...your expertise, please! ToniZ HVAC 0 09-05-2006 03:28 PM
5 Ton split system keeps shutting down mahjohn HVAC 1 06-10-2006 09:31 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 09:22 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
