Installing HVAC In An Older House. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 10:54 AM   #1
Installing HVAC in an older house.
So I'm battling with the idea of replacing my current method of cooling with AC. I replaced an old, undersized box evap cooler on my roof with a really nice breezaire cooler with all the bells and whistles. We've had it for two summers now, and although it keeps the house cool I hate the amount of moisture in the air. So my question is this, have any of you installed a complete system from scratch in an existing house and if so, what were the benefits/challenges of doing so? I'm not worried about the monthly electrical expense, as I believe my solar can cover the difference. Do you regret your decision? What was the going rate for a complete install in your area? I'm in western Colorado and was quoted between 9,500 and 20k by 5 different contractors. Thanks in advance.
DIbrYan is offline   Reply With Quote
Old 09-02-2013, 02:15 PM   #2
Experienced HVAC Tech
HVAC1000's Avatar
Hey I'm a contractor in northern colorado. And the price really depends on the difficulty of the job. If all 5 were about the same price maybe check with each and see what is going to be involved. Have each one walk you through the job see if walls need to be opened and if so if the repair or a cape deer it included in the job
HVAC1000 is offline   Reply With Quote
Old 09-02-2013, 04:23 PM   #3
The higher ones were to run a rigid trunk line and rigid ducts in the crawl space. The less were to either run insulated flex ducts in the attic and an air handler in the attic or garage or a roof unit. I was pretty specific about my needs and asked a ton of questions.
Installing yard lights on corners of house. tazman7 Electrical 15 05-07-2012 11:13 PM
installing vinyl siding around an electrical service on an older house huntercrow Carpentry 5 01-28-2011 05:12 PM
Installing plywood or chipboard over 1X6 planking on a 52 year old house' roof. JBfromSD Roofing/Siding 2 09-20-2010 11:09 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
