Old 08-31-2010, 06:20 PM   #1
Installing Hunter Programmable Thermo...Need help!
I have an old Trane thermostat and I'm looking to replace it with a Hunter programmable thermostat but I'm stuck at the wiring process. Below are some pictures of my old thermo still connected and the new thermo not connected. Can someone tell me which wires connect where? Thanks in advance.
Old:
New:
j3rman is offline   Reply With Quote
Old 08-31-2010, 07:29 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
You need to return the Hunter POS, and get a Honeywell that is for Heat pumps, or even contact your HVAC contractor in your area, and get a White Rogers. What is wrong with the Trane Thermo, that you decided to replace it?
Old 09-01-2010, 04:48 AM   #3
An old Tradesmen
You have a heat pump.
But that hunter(not worth its money stat) is not made for heat pumps.
Get a good Honeywell heat pump thermostat.
Old 09-01-2010, 08:39 AM   #4
There is nothing wrong with the Trane. Just wanted to try to save some money by installing a programmable thermo. Thanks for the advise. Guess I will return this one and get the correct one.
Line Voltage Programmable Thermostat for Off-peak studhauler Electrical 4 05-11-2010 05:38 PM
Hunter Model 44860 Programmable Thermostat MarkRhea General Discussion 2 04-05-2010 11:00 AM
Hooking up a hunter thermo from an analog carrier nelsonmay HVAC 5 09-29-2009 10:39 PM
Programmable thermostats, heat pumps and aux heat Crunkleton HVAC 3 04-21-2009 06:17 PM
installing wall box programmable timer rasta Electrical 8 11-12-2008 09:36 AM
