Installing Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 01:25 PM   #1
Rewards Points: 93
Installing humidifier
I just installed a AirKing (wait5000) humidifier on my furnace and it seems to be working well. My father purchased the same one but with a thermostat built into it since he doesnt have the wiring that goes to the main floor.
Problem is in the isntallation manual it shows that the round hole should be the same height as the warm air duct main unit hole. On my install there was an old drum style that i removed and the round cut-out hole was already about 3 inchs higher then the main unit and there seems to be no problems.
My dads furnace is a little more compact and his side return duct is 8 inchs and the airking (and most humi) takes 10 inchs. I was thinking of installing the main unit on the front or rear of the return duct instead, but this would make the 6 inch flex pipe have to have 2 bends and the unit wouldnt be the same height of the round opening to the plenium.
So what im really asking here, why do they have to be the same height? and is having one or two bends really that bad? (maybe use solid duct instead of flex)
simonb is offline   Reply With Quote
Old 02-04-2009, 02:36 PM   #2
They do not have to be the same as long as they attach to both ducts. Hum. mounted to return bypass piped to supply. An extra elbow or two won't hurt either.
You may also need to install a damper it the bypass if you have a/c.
SKIP4661 is offline   Reply With Quote
Old 02-04-2009, 02:48 PM   #3
Rewards Points: 93
Thanks for the quick reply. Myself i dont have an AC but my father does have one. What is a damper and how do I know if he will need one?
Is that the little round metal peice that you push in to block the round cut-out hole in the plenum?
Old 02-05-2009, 12:16 PM   #4
Rewards Points: 502
Yes. The damper is used to stop the airflow going through the humidifier during the summer months when the AC is on.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Installing Generalaire 1042 humidifier? vincee HVAC 1 01-01-2009 02:02 PM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 10:12 AM
Wiring a Humidifier tallcoopscoach Electrical 5 12-02-2008 02:00 PM
Installing a Furnace Humidifier pieman312 HVAC 1 01-08-2008 10:58 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
