Installing A Honeywell 5-1-1 'RTH2410??? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 09:58 PM   #1
Installing a Honeywell 5-1-1 'RTH2410???
Just purchased and unboxed the RTH2410 T Stat.
On page six it says if your old stat had an R wire this stat will not work.
My old stat was a simple Chromotherm with two wires. A red and white???
I think just purchased the wrong unit?
Skybeatle is offline   Reply With Quote
Old 03-27-2010, 10:15 PM   #2
What are you trying to operate with this? It sounds like it is heat only. I seen in the istructions where it said that but it also said alternate wiring. In the instructions under standard wiring it shows using R & W which is what you would use for heat only.
richiemoe is offline   Reply With Quote
The Following User Says Thank You to richiemoe For This Useful Post:
Skybeatle (03-27-2010)
Old 03-27-2010, 10:47 PM   #3
I read that myself. I re-install the old t-stat, then reread the instruction.
Yes, it is heat only for a carrier gas furnace.
The heat shuts off, but the fan keeps going. I can shut it off by shutting off the t-stat. The stat clock has quit working, so I decided the 5-1-1 was the best solution.
I was just a little late for the honeywell call center.
I will try their diy site.
Old 03-27-2010, 10:55 PM   #4
That t-stat should work. Your fan running all the time I don't think would be the stat. If you have 2 wires look inside furnace on board and see what they are hooked to should be R & W. I think carrier furnaces run the blower after you power them back on. That is if you shut the breaker or the ssu off.
Old 03-27-2010, 11:31 PM   #5
That's what I get for reading the instructions.
Should have just put R to R and W to W.
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 09:50 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Changing from one Honeywell to another... LeroyFrick HVAC 1 11-03-2007 11:33 AM
