Installing Heating Unit For A Flat Roof House - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2009, 10:48 PM   #1
installing heating unit for a flat roof house
Hello,
I have been living in a 1964 house and only source of heat is from 2 wood burning stoves. The owners told me that there is radiant ceiling heat which does not work...
I want to install forced air heating or heating of any other source any suggestions.....
gcampbell29 is offline   Reply With Quote
Old 02-21-2009, 11:26 PM   #2
Post how many sq ft and location.
hvaclover is offline   Reply With Quote
Old 02-21-2009, 11:34 PM   #3
2200 square feet and in california...I have a stupid question if there is supposed to be radiant ceiling heat and it doesn't work, how is it serviced?
Old 02-21-2009, 11:38 PM   #4
I don't know.
Old 02-22-2009, 05:32 AM   #5
G71
Pro
If it's electric radiant, call your electric provider, or your fav. electrician.
G71 is offline   Reply With Quote
Old 02-23-2009, 05:45 AM   #6
if you are only looking to put heat in and not a/c id save my money and buy some of those electric heaters that look like radiators you can buy three for less than 100 dollars and use them on the medium setting and only heat the rooms you are using youre probably looking at 7 to 10 grand for ductwork and a furnace ( if money is no object than of course go for it)
kennzz05 is offline   Reply With Quote
Old 02-23-2009, 06:34 AM   #7
An old Tradesmen
Rewards Points: 6,914
Lot of areas in Cal have electric rates of 17 cents a KWH.
Electric heat, can be expensive.
They make repair kits for ceiling radiant heat systems.
The repairs could be expensive, depending on how many reaks there are.
And sometimes, the owners, cut eh cables when they install new lights in the ceilings.
OP.
You might want to consider a pellet or corn stove.
They have a hopper you load the pellets or corn into. So it doesn't need to be watched like a wood stove.
Tags
flat roof , heating unit
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Heating Unit farooq Plumbing 2 07-18-2008 05:23 PM
large leaking tar flat roof erbilliards Roofing/Siding 2 03-16-2008 11:59 AM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 05:08 AM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
