Old 12-05-2012, 02:22 PM   #1
Installing heating accessory element
The unit has power. I installed the heating element and connected the 6 pin connector to the control board 031-01264-002. Thermostat wires is connected to red and white. This unit is not connected to a heat pump, will be used for electric heat only. Unit is not operating any suggestions?
Funderburk is offline   Reply With Quote
Old 12-05-2012, 03:28 PM   #2
JJboy's Avatar
Have you jumper R-W at control board?
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 12-05-2012, 04:29 PM   #3
HVAC Tech/Owner
whats you wire/breaker size to the airhandler?
Technow is offline   Reply With Quote
oven element not glowing all the way around diysNovice Appliances 10 01-20-2013 08:55 AM
Water Heater not heating pepsi3656 Plumbing 2 02-05-2011 01:32 PM
Tiling a bathroom floor and installing under floor heating tlovesb Flooring 6 02-04-2011 07:01 AM
I'm installing in-slab heating... outdoors. finndian Building & Construction 0 11-14-2010 03:01 AM
Oven Blew Up at Connector with Element cynthiap Appliances 5 11-26-2008 07:30 PM
