Installing Hardwood Floor Registers Don't Fit - HVAC - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 05:27 PM   #1
Rewards Points: 77
Hi, I'm installing a new 3/4 tongue and groove hardwood floor. The height of the hardwood floor prevents the existing baseboard register grills from fitting into the duct cutout. The register grills are the 12x 6 size. I was wanting the registers to sit on the finished floor but that makes them too high to fit into the wall cutout. I did not want to have to fit the floor around the register therby "trapping" the register with the flooring. I didn't know whether to post this in hvac or flooring. Any ideas?
SS396 is offline   Reply With Quote
Old 05-09-2013, 05:43 PM   #2
Rewards Points: 14,312
Post a picture. I've never seen wall registers that close to the floor.
Old 05-09-2013, 06:03 PM   #3
DIY staff
Rewards Points: 7,174
There are several types of wall registers--post the picture of what you have and the opening---
Some times the existing base molding needs to be trimmed a bit----but ,with a multi-tool, that job is not hard to do.
Old 05-10-2013, 12:58 AM   #4
REP
He has baseboard registers.They are as common as rain.If he pushes the boot up from the basement they will go higher than the baseboard.I think what he has to do is push them up and put a moulding around the top of them.
REP is offline   Reply With Quote
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
installing hardwood hidden1 Flooring 4 03-11-2013 11:17 AM
Installing Hardwood Floors kje7713 Flooring 7 02-16-2013 06:46 PM
Installing engineered hardwood flooring over concrete deborahs Flooring 3 07-30-2009 09:35 PM
Method for installing 3/8" engineered hardwood poolecw Flooring 10 10-31-2008 03:10 PM
