Installing A Furnace In My Shop - HVAC - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 11:57 AM   #1
Installing a furnace in my shop
I replace my house furnace with a new furnace. I want to install the old furnace in my Wood shop. I was going to put the furnace in the garage and pipe the heat into the shop. So the furnace will be in a separate unheated room. One question I have is about the cold air return. Do I need to pipe that into the shop as well? My concern is forcing air into a room with no air return. The shop is not air tight by any means but still. The other problem I have is it ok to put the furnace in an unheated room and will that cause it to run more/less efficient? I could put the furnace in the shop but, I was afraid of wood dust and open flames. Any help would be appreaded.
pdwoods55 is offline   Reply With Quote
Old 11-15-2010, 06:24 PM   #2
An old Tradesmen
Rewards Points: 6,538
IS it a 90%/condensing furnace? If it is. You need to make sure it never gets cold enough to freeze the condensate drain or trap.
Installed in a garage. It must have its burners and blower motor a min of 18" above the floor. Its a fire code.
Next. it must have a supply and return duct to the shop. And may not draw or discharge any air from or into the garage.
The Following User Says Thank You to beenthere For This Useful Post:
pdwoods55 (11-16-2010)
Old 11-16-2010, 12:39 PM   #3
Thanks Beenthere. It's not a high effecent furnace so that is not a problem. I didn't know about the 18" but meet that requirement anyway.
Old 11-16-2010, 06:03 PM   #4
An old Tradesmen
Your welcome.
Stay warm.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Installing new furnace question. csacsa HVAC 13 09-02-2009 06:35 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 09:07 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
