Installing A Furnace Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2008, 01:19 PM   #1
Installing a Furnace Humidifier
I am wanting to install a furnace humidifier unit.
Most units at local building supply store look fairly simple to install,
however the air intact/outlets on my furnace are fiberglass and not
sheet metal. Of course, all of the installation instructions i have looked
at show the sheet metal installation and not fiberglass so, here is the
question of the day: can these humidifier units be installed on the fiberglass
inlet/outlets and, if so, is there anything extra that should be done for reinforcing said unit
everyones help is appreciated!
pieman312 is offline   Reply With Quote
Old 01-08-2008, 09:58 PM   #2
biggles's Avatar
Aprilaire units(turning wheel with the round absorber plates) mount on the discharge duct just down from the furnace and hold about a gallon of water at 8lbs + the could support the opening that the humidifier will slide into from the ceiling with 2" bands of sheet metal shaped around the 3 sides of the duct and secured into the ceiling.if the duct runs along a wall a shelf built out to hold the humidifier might work
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 08:07 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
