Installing Furnace In Attic - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 09:20 AM   #1
Installing furnace in attic
I want to install a forced air heating system in a 1000 sq. ft. attic. I need to know whether I should install the vents in the attic floor or coming down the side walls? What are the advantages of doing it either way? Do you have a recommendation for furnace type and BTUs? Can you recommend a retail outlet in northern NJ? Thanks a lot.
doingitmyself is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Gas furnace in SPF sealed attic dmcmillen HVAC 4 06-27-2009 09:39 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
