Installing Floor Register Boot ? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 11:46 AM   #1
Rewards Points: 226
installing floor register boot ?
this boot was moved to a better location. it was already bent for the screws. so i used it as is. see pics. but this somehow doesn't seem to be the proper way of doing it. what is the correct way ? i need to put one in another bedroom. and i want to do it correctly.
installing floor register boot ?-009.jpg   installing floor register boot ?-010.jpg
Fix'n it is online now   Reply With Quote
Old 11-18-2012, 12:01 PM   #2
An old Tradesmen
Rewards Points: 6,592
It inserts from the bottom up, and then is screwed fast to the sides.
Old 11-18-2012, 10:07 PM   #3
Rewards Points: 226
ok thanx.
Old 11-19-2012, 07:11 AM   #4
Rewards Points: 1,216
Bring the metal up through the floor and then bend it over instead of it being bent over under the floor. If the metal is not long enough buy another boot with a longer throat.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-19-2012, 08:16 AM   #5
Rewards Points: 582
yep bring it to flush with finish floor screw or nail through sides...tip...make sure sides are good and straight or putting in register with be a ...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (11-20-2012)
Old 11-19-2012, 11:15 PM   #6
Rewards Points: 226
thanx guys
Vent Pipe Boot handy man88 Roofing/Siding 19 05-14-2012 02:18 AM
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 03:21 PM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 09:07 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 06:26 AM
