-   -   installing floor register boot ? (http://www.diychatroom.com/f17/installing-floor-register-boot-163826/)
Fix'n it 11-18-2012 11:46 AM
2 Attachment(s)
this boot was moved to a better location. it was already bent for the screws. so i used it as is. see pics. but this somehow doesn't seem to be the proper way of doing it. what is the correct way ? i need to put one in another bedroom. and i want to do it correctly.
beenthere 11-18-2012 12:01 PM
It inserts from the bottom up, and then is screwed fast to the sides.
Fix'n it 11-18-2012 10:07 PM
ok thanx.
COLDIRON 11-19-2012 07:11 AM
Bring the metal up through the floor and then bend it over instead of it being bent over under the floor. If the metal is not long enough buy another boot with a longer throat.
ben's plumbing 11-19-2012 08:16 AM
yep bring it to flush with finish floor screw or nail through sides...tip...make sure sides are good and straight or putting in register with be a :censored:...ben sr
Fix'n it 11-19-2012 11:15 PM
thanx guys
