Installing Electric Heat In Attic - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2012, 10:00 PM   #1
Installing Electric Heat in Attic
My house has a steam heating system that provides very nice heat, however, it does not provide much heat to the attic. The attic is finished.
I am contemplating installing electric heat in the attic. This would heat only the attic while the rest of the house is heated by the oil burner steam system.
Any thoughts on this? Good idea?
jtslue24 is offline   Reply With Quote
Old 10-21-2012, 07:18 AM   #2
Rewards Points: 1,214
As long as the attic is insulated good and you have the electrical service to connect the proper size circuit breaker, why not.
Seems to me it would be a lot easier to run a wire and install a breaker with a length of baseboard than to run steam lines up there.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 10-22-2012, 06:14 AM   #3
Thread killer
Rewards Points: 272
Do you already have rads up there that aren't working or you don't have anything up there?
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 10-22-2012, 08:59 AM   #4
I think that is the way to go it even comes with its own thermostat so you can heat the attic when needed .
ManuelR is offline   Reply With Quote
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Heat Pump, dual system, all electric, compressor not working rlc5669 HVAC 16 01-04-2011 08:59 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Better for heat pump or electric coil/strip? Lori 48616 HVAC 5 09-05-2008 03:28 PM
