Old 06-29-2008, 01:13 PM   #1
Installing Dimmer for fireplace blower
I've recently finished installing a fireplace in my basement. When I installed the blower I put it on a switch that I can get to from the wall. This works, but I'd really like to replace this switch with some type of dimmer so that I can control the fan speed. I've tried a standard light dimmer that I picked up at home depot, but that didn't work. It made the blower run slowly, even when the dimmer was all the way up. The specs on the blower are 115V, .85 A. The dimmer I had purchased was rated at 600 W.
Any thoughts on what kind of dimmer I should use or where to get one?
MountainMan is offline   Reply With Quote
Old 06-29-2008, 01:22 PM   #2
is the motor 3 speed
geo fan is offline   Reply With Quote
Old 06-29-2008, 01:28 PM   #3
No. The blower does have an analog control knob located in the fireplace itself that does exactly what I want it to do, but I need access to it from the wall. I've been searching through all of the documentation, but I can't find any specs on that knob control.
The blower itself is a Desa model BKT.
Old 06-29-2008, 03:16 PM   #4
Idiot Emeritus
A light dimmer is different than a motor speed control. They're not interchangeable.
Grainger has one, item#4C331 (ivory) or #6E897 (white). They're both made by Broan, model 57V (ivory) or 57W (White). These are designed for high-end bathroom fans, but your fireplace blower has the same type of motor.
Rob
micromind is offline   Reply With Quote
Old 07-03-2008, 12:09 AM   #5
Sorry for the delayed response I was on vacation. Thanks for the info! I'll take a look at that, it sounds like it's exactly what I need.
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Installing Aspire Remote Smart Dimmer sk72 Electrical 8 03-19-2008 10:16 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Installing a dimmer xray328 Electrical 5 02-24-2007 07:31 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
