Installing Cold Air Return Vent In Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2012, 05:36 PM   #1
Installing cold air return vent in basement
Hi!
We are redoing our basement and have a question we can't find the answer to! We have a cold hair return installed into the top of two studs (near the ceiling of the would be wall). There are vent brackets near the bottom of the wall but we are wondering if we have to install any specific ductwork from the return pipe to the would be vent ear the floor, or just sheet rock over it and the air will just use the path in between the studs and the sheet rock.
I am trying to attach a picture to make more sense. Thanks!!
Mrsolson is offline   Reply With Quote
Old 11-24-2012, 06:18 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
You'd need to seal the joists with mastick or use fiberglass ductboard and tape, something so as the wall chase is sealed completely, so that it can be used as a return air chase.
Very common.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Mrsolson (11-24-2012)
Old 11-24-2012, 06:56 PM   #3
An old Tradesmen
Rewards Points: 8,236
You can just sheet rock over it. but you should put a bead of caulk on the studs and plates to seal the sheet rock to them so its air tight. Including he other side of the wall.
The Following User Says Thank You to beenthere For This Useful Post:
Vent questions for basement barsink danielrg Plumbing 7 08-28-2011 02:33 PM
Vent Bath Exhaust to Cold Air Return? brandon272 HVAC 12 03-28-2011 05:11 AM
furnace cold air return vent placement flee HVAC 6 03-18-2011 12:06 AM
HEating vents and cold air return in basement hazey313 Building & Construction 3 09-30-2010 08:55 PM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 08:42 AM
