Installing Ceiling Vent Covers - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 06:29 PM   #1
Installing Ceiling Vent covers
Maybe I am over thinking this, but I am not quite sure how ceiling vent covers are installed. My basement remodel book mentions installing them by "screwing into the metal flange around the opening". Is the author talking about screwing into the sides of the boot? Or do I need to have 2x4's framed around my boots on each side?
Thanks,
Bryan
bkeech is offline   Reply With Quote
Old 01-27-2010, 06:52 PM   #2
Houston204's Avatar
Rewards Points: 556
Drive the screws into the boot.
I've only heard members of my company refer to register boxes as boots before.
I always get a strange look when I ask for boots at a supply house.
Houston204 is offline   Reply With Quote
Old 01-27-2010, 08:44 PM   #3
Actualy you button lock boot ears onto boot. The ears will span between the joists and give you a place to screw in to. Never saw the ears available at any supply house, we just make them at the shop. They look like a square root sign,5/8 down+5/8 up + a 12 to 15" extension.
If you can't come up with the ears then you will need wood along the boot edges for screws.
Old 01-27-2010, 11:20 PM   #4
Houston204's Avatar
Rewards Points: 556
Never heard of button locks.
With metal boots, why not drive the screw into the boot?
Are you speaking of ductboard?
Old 01-28-2010, 07:52 AM   #5
30 year tech
hvac122's Avatar
Unless you buy a special boot that is made with ears on it you must add the ears to the boot and hang it that way before drywall. It is just a flange of sheetmetal that buttonlocks to the boot. It gives you a place to secure the boot to hang it on rough in and gives you a place to secure register to on finish.
I have no idea how you would skrew a register into the boot as there is no flange.
hvac122 is offline   Reply With Quote
Old 01-29-2010, 03:05 PM   #6
Houston204's Avatar
Rewards Points: 556
I guess I'm buying special boots and never realized it.
So your 8x10 boot has a 8x10 box not 10 x 12 with an 8x10 opening?
Old 01-29-2010, 03:16 PM   #7
30 year tech
hvac122's Avatar
I suppose it all depends on where you live as to what is normal or special.
We just buy a boot that would go in the floor around here and put ears on it to install in a ceiling or a wall. 4 x 10 is our most common size.
Old 02-03-2010, 10:20 AM   #8
so I have a couple registers that I already drywalled with nothing but the box there. What can I do for these? Drywall anchors?
For the ones not drywall yet, I can take sheet metal and make something to screw into?
Old 02-03-2010, 10:44 AM   #9
30 year tech
hvac122's Avatar
Drywall anchors will be tough as the holes for the registers are real close to the hole you already have and will usually break the drywall. I would try to get some metal and make a short ear to squeeze next to the boot.
For the ones not drywalled we make a ear 1/2upx 1/2down x 4 at 90 degree or so and buttonlock it to the boot. That way you have something to skrew to.
Old 02-03-2010, 11:24 AM   #10
Thanks.
So can you describe what buttonlocking is?
Old 02-03-2010, 01:31 PM   #11
30 year tech
hvac122's Avatar
Its a punch tool for buttoning together two pieces of metal. Kind of presses/locks them together.
Old 02-03-2010, 06:01 PM   #12
Malco brand -snap lock punch -is the tool. Guess buttonlock is a slang term.
Need advise installing soffit vent scrupul0us Roofing/Siding 11 10-09-2010 07:57 PM
To Vent or not to Vent, that is the question debster Roofing/Siding 5 08-10-2009 04:48 PM
HVAC Ceiling vent falling off, how to fix? guile Building & Construction 4 01-20-2009 02:44 PM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 08:10 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
