Installing A Cast Iron Baseboard - HVAC - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 08:40 PM   #1
Just call me Andrew
Rewards Points: 1,020
Installing a cast iron baseboard
I am redoing my bathroom and want to swap out a cast iron radiator with a baseboard. I got a 2' section from my local supply house, it's one of these Burnham (pictured below).
I don't know if the guy doing my bathroom has ever installed these before. Anything in particular to know? Why are there two holes on each side?
Should I install drywall behind the unit? I have read things about putting a foil reflector behind the unit to make them more effective. Is it ok to NOT drywall behind the unit, as to "recess" it 1/2" into the wall. It would be right up against the studs in this scenario with insulation behind it (outside wall). Is this ok?
Here's the product sheet from Burnham:
http://www.usboiler.burnham.com/prod...iators/baseray
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 03-21-2010, 09:12 PM   #2
bbo
it looks like page 8 will give you the info on allowable depth of install:
http://www.usboiler.burnham.com/pdf/baseray_io.pdf
bbo is offline   Reply With Quote
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 08:55 PM
Cast Iron Baseboard heat Issue bmac1967 HVAC 11 10-22-2009 10:51 PM
Cast Iron Baseboard Installation Bob G. HVAC 7 09-15-2009 09:22 AM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
