Installing Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 06-18-2005, 07:59 PM   #1
I just purchased a Goodman AEPT36 air handler and I'm having trouble figuring out how to mount it in the vertical posistion. I'm going to install it in the garage. The air outlet is on the top which is no problem but the return is on the bottom under the AH so I have to elevate it some how to connect a return plenum and filter. Do they make a stand for air handlers? Goodman says you can mount these horizontal or vertical but they don't tell how. Horizontal would be easier but I dont have the room for that. When I purchased the unit I was under the impression that the return was on the side at the bottom not directly under the unit or I would have never bought it. Any help on this would be greatly appreciated. I would hate to spend an other $300 to ship it back.
Mark
Mark_mark is offline   Reply With Quote
Old 06-23-2005, 10:51 PM   #2
Hey Mark,
I installed one not too long ago and what I did is I built a stand out of 2x4 and plywood. It does not take much work and it worked good.
rlmcjunk is offline   Reply With Quote
Old 06-25-2005, 12:38 AM   #3
you can build it out of wood ,and creat a return duct for the unit to sit on,but if it is in an open area i would get a sheet metal guy to fab a plenum base out of 18- 20 ga galv metal that you could tap a filter rack and r/a drop into.this would look like an installer put it in .this shouldnt cost more than 100$ for this base ,it basically is a piece of duct with an end cap and the raw edge turned in for the unit to sit on .though if you get a wrap type base with viens in it ,it will be more$$$also ,or install it up high on angle brackets.dont forget to seal any duct that is under a negative preasure in the garage ,you dont want to pump garage fumes into your house.there is so many ways to install ,it depends on you,and your budget
murray is offline   Reply With Quote
Old 06-19-2010, 08:10 AM   #4
flipping the air handler
Hey mark,i have a simular problem,i purchased a goodman air handler, model # aruf303016, thinking it was a down draft unit,with the supply in the bottom,and the return in the top,i am installing it vertical,once i started reading about it,and found out the return was in the bottom(where my trunk line is),i freaked out,thinking i was going to have to send it back,i talked to an old friend of mine,who does hvac work,said relax,you can flip the unit upside down and coil around,add a drip pan,and move the blower around,and it would work. so now my only problem is getting under the house to run the line set,i only have about a 24 inch crawl space,good luck with your project...Dave
jack of none is offline   Reply With Quote
Old 06-19-2010, 09:02 AM   #5
Hopefully he's done since it's been 5 years.
Old 06-19-2010, 09:45 AM   #6
An old Tradesmen
Rewards Points: 7,818
LOL... Only 5 years.
Hope you used the DPI kit like you were suppose to for the conversion to downflow.
If not. You'll have lots of problems.
Old 06-19-2010, 11:58 AM   #7
five years
Whats up been there, i noticed the date after i had posted..oops,any way,the dpi kit,thats the insulation kit that goes under the coil?,this is my first install,hoping to save some money, im a maintenace man by trade,but have never done any hvac for the house. I really opened up a can of worms,tha house was built in 1946,it was moved to the present location in the late sixtys,i think they put the duct work down before the house was dropped, when i pulled the old furnace out,which was an oil unit,water had been leakin down the stack for years,and the trunk line is rotted out,to replace it,i would have to pull alot of the floor up,im gonna have to get under the house and dig enough room to just get to where the line set comes up into the furnace closet,any insight would be great...Dave
Old 06-19-2010, 12:22 PM   #8
An old Tradesmen
There are baffles that need to be installed on that coil(comes with kit). Or the blower will suck the water out of the drain pan.
The Following User Says Thank You to beenthere For This Useful Post:
jack of none (06-19-2010)
Old 06-19-2010, 12:29 PM   #9
dpi kit
Thanks again, i just got off the web sight where i purchased my unit,they have three different dpi kits,but it dosn't say anywhere which one fits my unit,i am gonna try to contact them,...Dave
Old 06-19-2010, 12:41 PM   #10
An old Tradesmen
Air handler model 018-32 DPI18-20/30
Air handler model 036-42 DPI36-42/30
Air handler model 048-61 DPI48-61/30
Above should be listed in your install manual.
Old 06-19-2010, 04:22 PM   #11
dpi kit
Thanks again been there,mine use's the 42/30,i took the coil out,flipped all the brackets over,now i just have to wait till the kit comes in the mail, i also installed the heat strip kit,it was a 15kw,but i knocked it down to 10, i didn't want to upgrade my service to 200 amp. something i should have checked before orderin a 15 k. the next obstackle is get under the house to install my line set,just set off a bug bomb,so its time to grab the shovel! lol
Old 08-06-2011, 03:10 PM   #12
REP
I can't believe that ANY code allows a furnace of any kind to be installed in a garage.
The ducting too and from the garage wwould bring in motor exhaust into the house.
That is exactly how some people end up dead in their bed.
REP is offline   Reply With Quote
Old 08-06-2011, 04:15 PM   #13
Rewards Points: 6,652
Or the fact that you pulled up a thread started over six years ago from its grave.
Old 08-06-2011, 04:19 PM   #14
An old Tradesmen
Code permits furnaces and air handlers to be installed in a garage. Duct work must be sealed/or chased.
Old 08-06-2011, 04:23 PM   #15
An old Tradesmen
Actually, it was a spammer that revived this thread. He and his post are gone.
DIY Heat Pump/Air Handler replacement hennyh HVAC 62 06-18-2012 05:11 PM
Installing Quarter Round shanmon Flooring 4 07-19-2007 12:59 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 08:14 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
Drainage from air handler jack B HVAC 1 05-07-2006 08:35 AM
